Ok I found out why VMB is turning into complete static mess for sound coming in/out of the program.
If you turn off:
-Allow Applications to take exclusive control
-Give exclusive mode applications priority
This messes up the sound
With my USB mic if I turn off both of those, it turns into a absolute static mess.
Turning that off with my Nvidia HDMI out causes all sound from VMB to become garbled crap.
So THAT is why VMB is having all these audio problems with Windows 10, with windows 7 this was not an issue, with windows 10 it is.
I have hereby SOLVED the static issue I was having with input/outputs.
This is probably something that should be noted. Exclusive mode needs to be checked in device drivers if its enabled in VMB as this was not an issue with Windows 7 when I had it installed (Maybe my hardware is unique/weird?)
[SOLVED!] why VMB on Windows 10 turns into static mess
ShamisOMally
Re: [SOLVED!] why VMB on Windows 10 turns into static mess
This is a problem more pending on hardware configruation and drivers
Unplug USB audio device, can cause different trouble, possibly stopping audio engine or entering in a unstable audio stream.
usually restarting the audio engine (see menu) fix the problem.
The main point with Voicemeeter is to have a stable main ausio stream,
this is given by the output device selected as output A1
you can attach a screenshot of your Voicemeeter System Settings Dialog Box, to let us know more about your configuration...
ShamisOMally
Downside is since figuring this out, setting mic back on to "Allow exclusive" instead of on, I just saw when coming back my mic had errored out, setting WDM to 576 and I'll see if that fixes it
ha, ok , good,
Generally speaking, i recommend to stay in audio engine default mode.
WDM Input Exclusive Mode is not stable in many configurations (BUG in WASAPI - seems to be still there under WIN10).
Engine Mode: Normal or Swift can be more or less adapted, pending on audio device connected to Voicemeeter, but the Normal Mode is expected to work in all configuration cases, the Switf mode can improve the audio stream stability when using low latency but it's not absolute (i mean in some cases, Swift Mode could work not better than Normal mode).
