Set Youtube as hardware input?
Strentin
Post by Strentin »
Hi there,
I use voicemeeter quite often and I really like it so far. I was wondering if it's possible to set Youtube or a Webbrowser in general as a Hardware input. or If I have offline music stored how can I play it so other people can hear it?
Best Regards,
Strentin
Re: Set Youtube as hardware input?
normally you set your Voicemeeter Virtual Audio input as default playback device to get all PC-Sounds into the Voicemeeter Virtual Input...
But you can also route PC-Sound to a physical input of Voicemeeter by using VB-CABLE...
to know more about this, i recommend to follow the user manual step by step (up to the USE CASE #1 maybe)
http://vb-audio.pagesperso-orange.fr/Vo ... Manual.pdf
