Where are the button scripts stored?
RalphShnelvar
Post by RalphShnelvar »
I have two machines using VoiceMeeter.
Where are the button scripts stored so I can copy the scripts from one machine to another?
Re: Where are the button scripts stored?
MacroButtonConfig.xml is in "My Document \ Voicemeeter" folder.
However, you also have Save / Load functions to manage Macro Buttons Config Files ...
see in system menu of the dialog box:
