Can't get VBAN-Spot to connect
Abnormaalz
Post by Abnormaalz »
Hello everybody,
I've installed VBAN-Spot and got my audio linked to it, and it is also ping testing devices, but it does not connect and stream the audio to the devices. Is this a problem on the Spot side or on the Receptor side?
Re: Can't get VBAN-Spot to connect
On VBAN-Spot if there is a green indicator beside the ip-address, it means the stream is sent.
then you can see on receptor device that a stream is received.
so you have to click on CONNECT button on the Receptor Lite for example to activate the stream listening.
if it does not work, check your network ip Range, it must include the IP-Address of your device.
