Hardware Input 1 = Mic Input freezed after a while.
prettynice
Post by prettynice »
Like i said in the topic...Hardware Input 1, which is my microfon, is freezing after a while and i have to do a "Restart Audio Engine" to get it back to work.
This happens since 2 days, after 8 month with no problems.
Im on Windows 10.
Just for information: 2 days ago, i installed "ScpTool" to get a PS3 Controller to work with my PC through USB. This tool had to install some drivers. Other then that, i didnt change nothing.
Re: Hardware Input 1 = Mic Input freezed after a while.
is it a USB MIC ? what audio interface did you select for it ? WDM, KS or MME ?
did you change some system settings in the Voicemeeter System Settings Dialog box ? screenshot ?
prettynice
It is a USB-Mic, yes. It's the AT2020USB+
Do you see the "2-" right before the name of the mic at Input 1. This is new.
Regular it says "AT2020USB+". Now it says "2-AT2020USB+". What happened?
Like i said before, i was good with these settings below for 8-9 Month, no Problems...
I need help.
prettynice wrote: Do you see the "2-" right before the name of the mic at Input 1. This is new.
it could mean you have plugged your device on another USB port, then the system has re-installed the driver for this USB port, then it adds a number on device name.
I think the problem is more on Windows USB Audio stuff... maybe you can reset the WDM buffer size to default = 512 sample.
prettynice
for now, i did not change the buffer yet. When it happens , i reactive the mic. But its really kinda strange...
i'm afraid there is many strange things on WIN10
prettynice
where to change the buffer size like you said?
in voicemeeter system settings dialog box (in menu).
prettynice
Ok. What the actually point of this "buffering". Please explain.
prettynice
Again. Mic stopped after ca. 30 minutes working with the new buffer settings.
Will try another USB Slot now...
This is horrible. No way to stream like that...
