Hi
This is a request to be able to assign multiple (or at last 2) hotkeys to VM Banana Macros in a similar way that OBS has the ability to map multiple hotkeys.
Currently only one can be assigned, but there are instances where having multiple assigned is required.
For example, if holding the shift key during a game that's being streamed or recorded and I need to activate/deactivate a 2 Position hotkey, then the macro isn't triggered unless the the shift key is released and tried again.
This causes problems when:
a) The change in audio isn't monitored in my headphones then it goes unchanged and messes up the audio capture.
b) The same hotkey(s) are also use to trigger actions in other applications (which triggers successfully), so the hotkey actions between the applications get out of sync.
Request: VM Macro Buttons - Multiple Hotkeys
weeemrcb
Re: Request: VM Macro Buttons - Multiple Hotkeys
you have the "*+ key" selection allowign to select a key that will work whatever the state of SHIFT, CTL, ALT keys.
otherwise you may define 2 buttons with the same script but different shortcut key.
