So after the April W10 update I've had some problems get VMB to work correctly with my speakers. I've done an uninstall and full reinstall of both VMB and Cable-VB with no luck.
My headset is set as A1, and my speakers are set to A2. Audio makes it to my headphones when I enable audio output to A1, but nothing comes out of my speakers when set to A2. I've even reloaded the exact same preferences I had set prior to the Windows update with no luck.
VMB No longer sends sound to my speakers
Re: VMB No longer sends sound to my speakers
you may check all your windows audio config and take a look on this topic:
viewtopic.php?f=6&t=442
