Voicemeeter Banana macro button
narutohokager
Post by narutohokager »
I created a macro to mute a "hardware input" (my mic) and it work well but when i'm in a fullscreen game, the macro doesn't work at all, even with the "Exclusive key" checked.
I also wanted to assign this macro to the little "2" key on the top left of the keyboard, here's a pic so you know which key i am talking about:
But i can't find this key in the Keyboard Shortcut of Voicemeeter ?
Here's my macro :
Can someone help me with that ? :?
Re: Voicemeeter Banana macro button
your MACRO should work when typing CTRL+B
if not, it means the CTRL+B is exclusively used by another application... try another key to check it...
REM: "exclusive mode" means the key won't be forwarded to other possible applications (registered to receive keyboard shortcut after macrobuttons)
narutohokager
I tried multiple others keyboard shortcuts but it's the same, when i'm in a game fullscreen, i can't get the shortcut to work...
maybe the game is taking all keys in exclusive mode ... or in hotkey mode...
try to run Macrobuttons before launching the game maybe...
narutohokager
Tried to run the macrobutton before launching the game but nop it's the same...
That's odd because i can use global key shortcut with VLC ingame for pause/resume music without any problem.
i should try to reproduce it... what is the game?
narutohokager
I tried in 3 differents games (CSGO, ROE, Dead by daylight)
The only one which is not working is in Ring of Elysium (ROE, free to play)
