[HELPER] Voicemeeter - Streaming Setup
tjglaser1s
Hello - If you're a Streamer and looking for any help with your setup feel free to reach out to me. I've gone through several setups for Mixer Streamers and integrating all the cables with Voicemeeter and OBS/SLOBS/X-Split.
InvisibleGardener
Re: [HELPER] Voicemeeter - Streaming Setup
Hi
yes I can use the help
I do several radio shows and need to stream music as well as voice
I use skype and zoom
how do you charge/work?
thanks
feel free to message me here
or use my email at andylopez@invisiblegardener.com
thanks again
thanks
thanks again
Pitz
Hey maybe you can help me too
following programs running:
Nvidea shadowplay: voice chat in is set to: Voicemeter AUX Input
Fortnite: voice chat in and output is set to Voicemeter AUX
Voicemeter Potato with settings seen in screenshot
Voicemeter AUX In- & Output is set as standard communication device
Voicemeter In- & Output is set as standard device
Audio Interface: Native Instruments Komplete Audio 6
it is working fine, except in Fortnite
if i go into the game sound is working, if i join a game lobby i get 80% of the time crackling sound, therefore i have a macro button to restart audio engine
it is working fine until i join another game lobby
soo every time i start a new game lobby i have to restart my audio engine
- VM3.PNG (29.18 KiB) Viewed 8828 times
- VM2.PNG (96.67 KiB) Viewed 8828 times
- VM1.PNG (195.91 KiB) Viewed 8828 times
