Windows Cannot Verify Driver Signature (on signed driver)
In rare cases, and especially with Windows 7 x64, we got the installation issue where virtual audio driver are installed but disabled because a digital signature problem. Even if forcing the Setup program to run in administrator mode.
The message given in the Device Manager for the disabled Driver is:
"Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)" in device status
The reason we found is a problem of Windows Update (preventing to admit recently signed drivers).
SOLUTIONS:
1- You may de-install this drivers and REBOOT.
2- You may update WINDOWS 7 with Control Panel / Windows Update
3- If your Windows Update does not work (stuck), you may follow this solution:
https://support.microsoft.com/en-ph/hel ... bleshooter
The goal is to update WINDOWS to let it understand the driver signature.
Windows update Failed to start (error 80072EFE)
User reported having solved this issue by installing the following updates:
1.Update for Windows 7 for x64-based Systems (KB3020369)
2.Update for Windows 7 (KB3125574):
To find the right package for your Windows 7 or server 2008 (32 or 64 bits) you may use the Microsoft Catalog Update site:
https://www.catalog.update.microsoft.co ... =KB3020369
https://www.catalog.update.microsoft.co ... =kb3125574
SHA-1 signatures will be deprecated by Microsoft
in 2021 the SHA-1 Code Signing algorithm will be replaced by the SHA-2 algorithm only.
(Dual Code Signing process could not be possible anymore... ).
Some old version of Windows 7 would need to be updated to support SHA-256 Certificates...
https://docs.microsoft.com/en-us/sysint ... eprecation
Windows 7 Update should contain the SHA-256 Certificates support anyway:
https://support.microsoft.com/en-us/top ... a4cde8e64f
Questionning: What consequences on driver maintenance for Windows 7 and 8 ?
https://www.osr.com/blog/2020/10/15/mic ... win7-win8/
