Mic stops working when SLOBS is running
mrgusse
Contact:
Post by mrgusse »
Hi I have some major issues with Voicemeeter Banana. Hopefully you can help me out.
Everytime I start Streamlabs OBS the microphone stops working immediately.
IN1 = Rode NT-USB
IN2 = Headset Mic (not in use)
IN3 = Cable A Output (Spotify goes to this)
V.IN = Default device
V.AUX = Default Communication device
A1 = Speakers (Realtek)
A2 = Headset (Asus Xonar U7)
A3 = Cable Input
Voicemeeter overview:
Voicemeeter system settings:
In Streamlabs I have made audio sources manually for everything except desktop audio, which is set in Audio Options to Voicemeeter Output
Microphone is set to a manual audio input capture = Voicemeeter AUX Output.
Music is set to a manual audio output capture = Cable A Input
VOIP is set to a manual audio output capture = Cable Input
Really don't know what to do, I have reinstalled cables and Voicemeeter on several occasions but something is clearly not working with my setup.
Please help!!
Ps. All voicemeeter and cables have exclusivity checked Ds.
Re: Mic stops working when SLOBS is running
did you check the default audio format of the different devices ?
did you check communication option in windows sound dialog box (must be set to DO NOTHING).
mrgusse
Contact:
Post by mrgusse »
Audio format, is that for example 24 bit / 48 KHz? I have set all to 48kHz and 16 or 24 bit
The only thing might be that Communication thing, has to be set on all devices I suppose.
no the communications options is global options
