Inconsistent volume levels
mcloum
Post by mcloum »
HI all,
Im having trouble using VMB when streaming. I set my levels and do a test recording in OBS which sounds absolutely fine. Game and voice levels are clear and fine including Spotify via a VACable. But when i stream the Mic volume is way too low, I have everything outputting to A1 (headphones) and B1 (OBS is listening on this)
An example is the following video https://www.twitch.tv/videos/382150167
I have the Mic set to +2Db in VM, i can increase it but then my mic will be much louder in Discord. You can hear my friend in Discord who is much louder and clearer, but im a lot lower.
I've been struggling with audio for months/years now and never really found a good balance using VM.
Any advise would greatly appreciated.
Re: Inconsistent volume levels
very strange.
so you mays check that all volume control are set to max in Windows Volume Mixer (related to all devices connected to Voicemeeter).
optionnally check default audio format used by recording devices (might be above or egual to 44.1 kHz)
