hi.
i've got a slight problem with the Banana VoiceMeeter...
I must restart the Audio-Engine like every 10 to 15 minutes... (yes, I've set the check at "Restart audio engine automaticly")
is there a Way (maybe in the Settings) that I can prevent this "bugs" ? (I know, it's not really a bug, but its not really a Feature too )
lg Michelle
Have to restart the Audio-Engine like every 10 Minutes...
Re: Have to restart the Audio-Engine like every 10 Minutes...
why do you have to restart audio engine ?
because the sound sounds awfule (like a robot and with electric noises)
so it means you have not a working configuration, you may change audio interface or audio device for output A1 :
follow recommendations there: viewtopic.php?f=6&t=451
