Gaps in audio when using VoiceMeeter Banana
onkeltem
Post by onkeltem »
Hi folks!
I experience strange problems on my system.
I use fresh install of Windows 7. I don't have any equipment, just playing some audio in browser or VLC. When I play it w/o VoiceMeeter it sounds smoothly, but once I enable VoiceMeeter the gaps start to appear in the stream. I recored a piece of it using Banana and opened in Audacity and saw gaps every other few seconds:
And here you can listen to it: https://soundcloud.com/artiom-neganov/r ... -01h25m40s
Do you have any ideas why could this happen?
Thanks in advance.
onkeltem
Re: Gaps in audio when using VoiceMeeter Banana
Post by onkeltem »
Anyone?
surely a configuration problem on Voicemeeter side...
you may send a screen shot of Voicemeeter and its system settings dialog box.
