so am using vban in my pc and I need it to send something from my pc and back to it, but sometimes my local IP changes is there any way I can set something that for example is like localhost to localhost that way I don't have to change the IP in settings or maybe a send to all network, I recall it supporting send to all but idk if it can receive to all as well, can somebody clarify me on this?
[edit 1]: if so what is the config for send to all in the IP thing is there somewhere that says that, i been trying to look for it but no luck
[vban] advice on vban settings
Re: [vban] advice on vban settings
use address 255 to broadcast audio to all your local network (works only on wired network, WIFI AP do no like this at all).
iurirolho
sorry only now saw this i forgot to logon on website, i will re adjust the ip now thank you
