VB-CABLE is a virtual audio device working as Virtual Audio Cable
As virtual cable, VB-Cable can be used to connect two applications together, typically a player application to a recorder application.
Official Page: http://www.vb-cable.com (download, user manual and video tutorial)
VB-CABLE INSTALLATION PROCESS: STEP BY STEP:
1-Download zip on your local disk (C: system disk).
2-Extract all files in one folder (e.g. temporary folder on C: System Disk "C:\temp")
3-From this local temporary folder: Run Setup program in administrator mode (right click on exe to see the “run as administrator”)
4-Follow instruction : REBOOT after installation
IMPORTANT WARNING: REBOOT AFTER INSTALLATION AND DE-INSTALLATION
(Virtual Audio Device Driver needs this reboot to finalize de-installation or installation)
U P D A T E
UNINSTALL FIRST:
0- Close applications that could the VB-CABLE driver (OBS, Audacity...).
1- Run the Setup program and push the button REMOVE.
2- REBOOT AFTER (IMPORTANT)
Before re-installing you may check
- in Windows Device Manager that VB-CABLE virtual audio drivers is removed (from the game controller section and from the audio I/O section) - if still present you may uninstall them manually from there.
THEN RE-INSTALL:
3- Run the Setup program in administrator mode and push the button INSTALL.
4- REBOOT AFTER (VERY IMPORTANT)
WARNING: the Setup program can be displayed as "not responding" because the installation process can takes several seconds... Just wait until the end of the setup sequence.
VB-CABLE Information
Missing 'inf' file... error
if you get the following message:
Missing 'inf' file or Driver Package Corrupted
it usually means you are running the SETUP program directly from the ZIP package.
that's why you must EXTRACT all files in a temporary or archive folder first and launch the SETUP program from this regular folder.
