[Feature Request] Macro Buttons Application and conditional if then else…
mipsou
Post by mipsou »
Happy New Year and best wishes…
I need to ignore macro auto ducking when strip was muted.
I dont found command with if…/then…/else…
Regards
Re: [Feature Request] Macro Buttons Application and conditional if then else…
there is no if / then / else instruction...
but the level option AFTER MUTE might do what you want.
