Voicemeeter Pro Preferred Main SampleRate
Posted: Sun Oct 26, 2014 7:09 am
Vincent,
If I have changed all my devices to 48000, and my Internal SR in all three CABLE control panels also to 48000 (referring to the VBCABLE_Control_Panel for the VBCABLE Virtual Cable its extraction/installation folder and the two for VAIO and VBVAUX in Voicemeeter's Program folder) then I imagine the Voicemeeter Pro "Preferred Main SampleRate" setting should also be at 48000, but I am not sure of that, or under what situations I might preferably set it to a different value. Could you clarify that point for me please?
Thanks!
Terry
Thanks!
Terry
