[ Potato ] How to record external FX with your DAW in a split channel?
mipsou
Postby mipsou » Sun Apr 14, 2019 10:32 pm
Salut,
How to record sound of external FX 1 in input 3 of the virtual ASIO mith my DAW inside Potato ?
There no way for me to record external fx in a split channel in my DAW. Did you foresee this scenario?
Regards
Re: [ Potato ] How to record external FX with your DAW in a split channel?
Postby Vincent Burel » Tue Apr 16, 2019 8:50 am
nop, this SEND PATH is not present in our virtual ASIO driver.
I guess you could use a BUS instead no ?
mipsou
Postby mipsou » Tue Apr 16, 2019 11:19 am
How can i use my external fx sound to return in my DAW ?
Return to “Voicemeeter”
