Hardware out, When I select WDM speakers it crashes my computer. When I select KS or SS USB headphones My computer goes into panic and crashes. i can only select MME speakers to keep from crashing my Windows 10 computer
What to do?
vince
Voicemeeter Hardware out WDM Speakers Crashes
starlite2991
Re: Voicemeeter Hardware out WDM Speakers Crashes
keep select MME...
to reply more precisely to your question would mean to diagnotostic you entire configuration.
starlite2991
VincentVincent Burel wrote:keep select MME...
to reply more precisely to your question would mean to diagnostic your entire configuration.
What is the difference in selecting WDM and other configuration? Okay to keep using MME? Windows 10. What should I look at for a problem? Also, I want to install your Software on another computer. Can I use another copy on 2 computers or I have to pay again for copy 2?
Vince
