Voicemeeter: Please add keybind option for tilde/backtick
Neyah
Postby Neyah » Mon Dec 02, 2019 12:34 am
For macrobutton hotkeys, can you please add support for selecting the `~ key?
https://docs.microsoft.com/en-us/window ... -key-codes
VK_OEM_3
0xC0
Used for miscellaneous characters; it can vary by keyboard.
For the US standard keyboard, the '`~' key
Thanks!
xcasxcursex
Re: Voicemeeter: Please add keybind option for tilde/backtick
Postby xcasxcursex » Wed May 27, 2020 2:54 pm
Bump for this request. I just made a new macro and wanted to bind it to CTRL+ALT+`
I was stumped because not only can I not use CTRL and ALT together, but I also cannot use the backtick/tilde key.
CTRL+ALT+F1 would have been OK, but I can't do that either.... Only CTRL+F1 or ALT+F1 :(
I attempted to use the XML to use both modifiers and the appropriate keycode, both separately and combined, to no avail. Even if this had to be done in such manner (no UI support, only editing config files) that would be enough.
Return to “Voicemeeter”
Users browsing this forum: No registered users and 12 guests
