Adjusting the sliders
gamerscircle
Post by gamerscircle »
Hi all!!
I have been using VM for a little over a year and it is amazing.. thank you for the software.
Is there a way that I can adjust the sliders a little more accurately? I can adjust from 9.9 to 10.6 and I was curious if there are any keyboard controls to get a little more finer adjustments?
Re: Adjusting the sliders
you can right click on it to directly enter the value...
ore use MacroButtons to progam a vol+ vol- with a very small step...
gamerscircle
Okay.. I feel like an idiot, thanks..
Say.. do you recommend any midi type interfaces for adjusting?
one of the cheapest is the Kork AnoKontrol, but normally all MIDI controlers shoud work.
