Hello!
Installing the VoicemeeterPro Setup Package (Version 2.0.6.2) also installs VB-Cable, or does it have to be separately downloaded and installed?
I ask this because I just downloaded and installed the VoicemeeterPro Setup Package in Windows 10, and although I can't see the virtual audio cable installed, I can see its files ("VBCABLE_Setup_x64.exe", etc.) in "C:\Program Files (x86)\VB\Voicemeeter". I can also see some VB-Cable related files in "C:\Program Files\VB\CABLEVM" and "C:\Program Files\VB\CABLEVMAUX" (3 files in each folder).
If VB-Cable has to be manually installed, in spite of what I just described above, should it be installed running "VBCABLE_Setup_x64.exe" from "C:\Program Files (x86)\VB\Voicemeeter", or does it require to be separately downloaded and installed on its own?
Thanks in advance for your help.
VoicemeeterPro Setup Package Installation and VB-Cable
GCG
Re: VoicemeeterPro Setup Package Installation and VB-Cable
Voicemeeter package installs 1,2 or 3 virtual audio cable used as virtual I/O (VAIO) for Voicemeeter virtual inputs and virtual output BUS.
these virtual audio cable are independent from VB-CABLEs (which are other virtual audio cable).
you may not use directly VBCABLE files included in Voicemeeter package, these are managed by the Voicemeeter installer only.
GCG
Thanks for your reply. I just wanted to make sure I was not unnecessarily bogging down my computer by downloading and installing things that may had been there already.
I'll proceed to download and install VB-Cable then
