Manual restart of audio engine necessary after every wakup from sleep
mgutt
Postby mgutt » Thu Dec 15, 2016 10:04 pm
I'm using Voicemeeter 1.0.5.1 with W10 x64. After my pc wake up from sleep (I do not use hybernation) Voicemeeter is still open, but as the audio is not working I need to select everytime "Restart audio engine":
Any solution for that?
EDIT: My problem is part of this problem:
viewtopic.php?f=6&t=403
As Voicemeeter blocks sleep mode the monitors switches off and after waking up the audio engine fails. But if I enter sleep mode manually and wake up from that the audio engine restarts on its own. So it must be connected with the sleep blocking.
Re: Manual restart of audio engine necessary after every wakup from sleep
Postby Vincent Burel » Tue Dec 20, 2016 9:34 am
Windows wake up is not so easy to manage since it can wake up audio devices in different order and wake up the applications using it before... and with the USB stack, the behavior cannot be the same from XP to WIN10... Manual restart is the better option for the moment...
metalmilitia623
Postby metalmilitia623 » Thu Jan 05, 2017 10:43 pm
This is why I have just made a macro button to allow me a shortcut to restart the engine. Once you have a shortcut this kinda becomes a non issue.
mgutt
Postby mgutt » Mon Jan 09, 2017 12:05 pm
Isn't there any event id for windows 10 to restart the audio engine through the task scheduler?
mgutt
Postby mgutt » Mon Jan 09, 2017 3:31 pm
Ok, I found a "solution":
http://superuser.com/questions/1165081/ ... windows-10
I created this trigger and start the application "C:\Program Files (x86)\VB\Voicemeeter\voicemeeterpro.exe" with the argument "-R" to restart it on logon.
Return to “Voicemeeter”
Users browsing this forum: No registered users and 13 guests
