Voicemeeter or Audio problem after WIN10/11 update (JUN 2023)
i don't understand this timer questions, because we do not request for 10000 periods (but 1000 only) and we have changed nothing on this since the beginning... very strange.
KayPure
Post by KayPure »
Hey,
Getting an BSOD after initial start of my Computer. I think, its after an Update too, but dont know which one. Its very odd. Im at this Point, where i consider to re-install Windows. And maybe not 11 Insider Build again :/
Starting the PC for the first Time of the Day > Voicemeeter starts > After the Countdown in the right Corner of VM, i get an BSOD (APC_INDEX_MISMATCH)
After a Reboot, Voicemeeter starts without Problems.
If i start the PC for the first Time of the Day and perform a direct restart, Voicemeeter starts without any Problems.
If i hibernate the PC after using and wakes it up, Voicemeeter is running without any Problems.
I updated Windows 11 (Insider Build) to all the latest s*it. Nothing helps. A Friend of mine got that BSOD too, but only once. I get it on every fresh Start of the PC. Perhaps u guys can check my Dumpfile and see, if there is anything i can do. Deactivate my Realtek Onboard is no Option for me, since this is my main Mic on that PC.
Here is the dmp File > https://drive.google.com/file/d/1DcKWKd ... sp=sharing
Cheers
Dump File : 092121-11906-01.dmp
Crash Time : 21.09.2021 07:42:19
Bug Check String : APC_INDEX_MISMATCH
Bug Check Code : 0x00000001
Parameter 1 : 00000000`77301cf3
Parameter 2 : 00000000`00000000
Parameter 3 : 00000000`fffe0000
Parameter 4 : ffffac8e`b5281b60
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+416080
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+416080
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\092121-11906-01.dmp
Processors Count : 16
Major Version : 15
Minor Version : 22458
Dump File Size : 1.110.332
Dump File Time : 21.09.2021 07:44:00
