Microphone problem
YUMM
Microphone problem
Postby YUMM » Tue Apr 03, 2018 9:14 am
I cannot seem to get Voicemeeter to recognize my microphone. It's not a USB, but has a mini plug connection. When I try and set hardware input 1 as my mic, it shows in the drop down list as a USB. No other mic option is shown. I use RadioDJ for my internet radio station, but I can't record any new promos etc because of the mic problem. Thanks for your help.
Re: Microphone problem
Postby Vincent Burel » Wed Apr 04, 2018 5:23 pm
does this mic appears in the Windows Audio devicerecoring list ?
check it's enabled and working (you can see incoming signal on the meter bar).
YUMM
Postby YUMM » Thu Apr 05, 2018 2:56 pm
The mic. shows up in the Windows Recording Devices. It says it's ready. No signal from the meter bar.
Postby Vincent Burel » Sat Apr 07, 2018 10:12 am
check your mic device is not muted in advanced tabs...
brickviking
Postby brickviking » Sun Apr 15, 2018 8:51 am
Does your microphone have an audio style 3.5mm connector on it? Those look like the following picture but will probably be pink or not-green:
Is it plugged into a socket connected to your motherboard? If it is, then check what Vincent said, look in your Recording Devices list to see if you can find something that looks like a microphone icon. It may show as Realtek Microphone, I can't say any alternatives.
If it doesn't look like that, and it doesn't look like the normal "big" USB connector, then let us know what it does look like. "Mini connector" in my experience covers a large number of potential plugs.
(Post 26)
Return to “Voicemeeter”
Users browsing this forum: Google [Bot] and 21 guests
