Voicemeeter Potato Preliminary Beta version
Jim
Re: Voicemeeter Potato Preliminary Beta version
Postby Jim » Fri Oct 12, 2018 6:03 pm
Jim wrote:Hi, Love the potato!
Bug: in the M.I.D.I. Mapping window there is an extra dot: M.I..D.I. Map Name
I would like to have the Intellipan/FX sections also on the virtual inputs.
// Jim
Just installed the pre-release.
It is still there ;)
ToxMox
Postby ToxMox » Fri Oct 12, 2018 8:14 pm
Any chance we'll see Midi feedback in Potato?
Postby Vincent Burel » Sat Oct 13, 2018 5:39 am
right, i forgot this MIDI typo mistake... i note it for next version.
MIDI feedback erquire to rethink the midi mapping interface and functions.. but it could be possible...
ToxMox
Postby ToxMox » Sat Oct 13, 2018 4:20 pm
Vincent Burel wrote:MIDI feedback erquire to rethink the midi mapping interface and functions.. but it could be possible...
This would be amazing! I personally would love to be able to link anything in Voicemeeter to a MIDI control and have feedback.
Maybe something that turns the regular interface into MIDI learning mode where it kind of has an overlay where you can click on any of the actual buttons or faders and bring up a MIDI learn dialog for it would be really cool.
mipsou
Postby mipsou » Tue Oct 16, 2018 9:58 pm
The last version is amazing and simple… Send bus and return bus work perfectly with direct i/o routing to Focusrite 18i20
I try now to manage insert.
Is it possible to make the inserts more accessible? (same as bus send and return)
mipsou
Postby mipsou » Thu Oct 18, 2018 6:59 pm
FYI
I manage voicemeter Potato's inserts from a Pedalboard 2
[*]Image
Add yours plugin with automation to live performance in stream.
For exemple add a logical remote command te enable or disable vocoder or other…
Enjoy…
PS add a system to send crash report to found more bug. Mine potato as crashed once. I've not details
mipsou
Postby mipsou » Sat Oct 20, 2018 4:23 pm
I have some trouble with the insert vaio potato.
I have a regular noise that corresponds to a cut of the sound streamer with the insert Asio Potato.
When I bypass the inserts, everything is normal.
Exemple
Postby Vincent Burel » Tue Oct 23, 2018 9:20 am
all virtual ASIO Driver stability are given by the main audio stream stability
what is your device selected as output A1 , with what buffer size (if buffer size is too small <256 smp, virtual ASIO driver can have problem to synchronize and then generate cut in the sound).
mipsou
Postby mipsou » Tue Oct 23, 2018 4:37 pm
I show you
All settings are default.
But I use insert so see below.
HostVST Pedalboard 2
Another blocking point for Pro Tools First, when creating a project that must be resampled in 44k1Hz
Call to VBA IO Control Panel have no effect
Empty project have the same trouble.
Postby Vincent Burel » Tue Oct 23, 2018 6:14 pm
ok you have problem on audio coming from DAW app connected to Voicemeeter Virtual ASIO.
Theoritically your configuration should work perfect!
But with Focusrite ASIO driver there is timing problem that can prevent our virtual ASIO driver to work correct:
more explantation there: viewtopic.php?f=11&t=506
try to change the buffer size to get better timing on focusrite ASIO Driver
Return to “Voicemeeter”
Users browsing this forum: No registered users and 15 guests
