PRE-FADER definition?
user4711
Re: PRE-FADER definition?
Postby user4711 » Thu Jan 17, 2019 1:14 pm
JBP wrote:
user4711 wrote:this give not good results and is hard to use
The BUS EQ gives good results if you use Channel Select option!
And if your speakers or/and headphones are not absolute garbage.
Maybe not 100 percent perfect, of course!
Some people trust measuring, others can trust their ears!
If you (as a super pro user) cannot live without impulse response measuring, then you have to use something else ( :arrow: Sonarworks Reference 4 Studio Edition - 299€) post Voicemeeter or keep your individual strip insert processing approach with correction via an appropiate VST Plugin.
I have said it already before:
One day we all wake up and Voicemeeter will be a meta-DAW if Vincent implements all feature requests! :mrgreen:
a vst slot is not a meta DAW. equalizer apo have a vst slot builtin and is no DAW, but it is very deep in the system, and after the big win 10 update which happen 2 times per year there need reinstall and there need change registry keys to public, and it cost many reboots to get it working again. because win 10 update you can not avoid, it can happen some day, that equalizer apo did not work anymore. it have since long time no updates get
I have idea for good working virtual devices with use of the CPU MMU memory exception handler. buffer start is buffer size -1 sample before a protected memory area. Now when the daw write the last sample of the buffer, the MMU trigger a memory access violation. the virtual device need install a exception handler before, so windows do not stop the program. In the exception handler of virtual device is then the buffer copy and process. this can work very fast. in computer emulators is such a technic used to process sound and video data.
the most important is that voicemeeter have good working virtual devices. the vbaudio cable did crackle often. other virtual devices do that too. maybe it is possible to release good working virtual devices . (i mean with good that they work same good as real audio card drivers, and have volume control ability) that can work everwhere as shared input and output. I do not understand way
trust ears i think not good because when boost high frequency and bass it always sound better but damage ears sooner or later when longer hear loud. hear a while with that settings and then remove high freq boosting and bass boosting and the original sound very worse. so ears work relative. there can also reduce high freq for test and when longer hear and switch back to normal, then all sound too bright.
thats the reason because most surround receiver have a measuring solution built in today. i think studio technoligy worser in compare to hifi technolify. in studio technology are digital outputs selden. speaker corrections not easy.
JBP
Postby JBP » Thu Jan 17, 2019 9:33 pm
user4711 wrote:
JBP wrote:I have said it already before:
That was obviously a general ironic statement, because I have written "all feature requests".
You prefer to misunderstand a statement, that cannot be misunderstood if read precisely.
I have asked you multiple times, if I helped you with the Minihost Modular ASIO Insert splitting example.
No answer!
Instead you give us good advices like this:
user4711 wrote:the most important is that voicemeeter have good working virtual devices……………maybe it is possible to release good working virtual devices……………i think studio technoligy worser in compare to hifi technolify……
Sorry, for me such kind of egocentric discussion approach (overflowing off-topic!) is pointless and leads to nothing.
If someone thinks I am rude (again?), I have to say:
No, I only give an appropriate response.
user4711
Postby user4711 » Thu Jan 17, 2019 10:32 pm
@JBP
Are you a programmer of voice meter or do you speak for the programmers ?. I ask this because your statement is as a VST slot you not wish. so i like know if this all voiceemeter developers see same, that there never come a VST slot
for record of audio i can use as before bandicam, choose in windows pref record and the output device. I have only ask if it is possible to use the voicemeeter recorder because it is more easy to use. bandycam record videos. so i need split later the audio
Postby Vincent Burel » Fri Jan 18, 2019 6:54 am
JBP is not programmer for VB-AUDIO and does not talk for VB-Audio.
I must remind that i've not the time to moderate this forum, so i recommend to limit useless discussion.
Return to “Voicemeeter”
Users browsing this forum: No registered users and 8 guests
