Voicemeeter Potato Crackling,distorted sound
Agent86
Re: Voicemeeter Potato Crackling,distorted sound
Postby Agent86 » Wed May 29, 2019 2:26 am
Have you tried to change your output buffer ?
Why are you using MME for everything ?
Why not WDM ?
Do you get crackling through B1 and B2 on their own ? Or only while streaming shadow play and OBS at the same time ?
Crackling in B1 and B2 may not be present in A1 because the output to your headset require different buffers or might require different buffers.
Try this.
-Set Engine Mode to Normal
-WDM input mode exclusive mode = NO
-WDM buffer to 480 and try see if that helps with this issue.
battlestrong
Postby battlestrong » Wed Jun 19, 2019 11:30 pm
Agent86 wrote:Have you tried to change your output buffer ?
Why not WDM ?
Try this.
Yes, I tried to change my output buffer size. I noticed that when I set a lower buffer size it doesn't do as much crackling as before, but it still doesn't fix the problem.
"Why are you using MME for everything ? Why not WDM ? " I was messing with settings at that time, that's why I was using MME.
"Do you get crackling through B1 and B2 on their own ? Or only while streaming shadow play and OBS at the same time ? " The conflict between audio is not appearing in OBS. In Shadowplay and even in discord crackling appears. (Discord=B1, Shadowplay=B2, OBS=B3)
"Crackling in B1 and B2 may not be present in A1 because the output to your headset require different buffers or might require different buffers." :?:
"Try this."
-I already tried to reset everything to default even windows reinstall didn't help
-480 Buffer size helps a bit I went ahead and tried all sorts of buffer sizes from the largest to the smallest and I noticed that the lower the buffer size is the less crackling there is, but it's still there and its noticeable.
Azp3ct-
Postby Azp3ct- » Sat Aug 17, 2019 11:02 am
any fix for this ?! Have the same Problem that discord starts sometimes cracking for me, so the people hear my voice same like yours. any solution ?
Return to “Voicemeeter”
Users browsing this forum: Google [Bot] and 10 guests
