Voicemeeter potato sound crackling/popping out on responsiveness loss and worse performance on wdm
iurirolho
Postby iurirolho » Sun Sep 15, 2019 8:57 pm
am running atm mme, and i get some popping sound slash crackling when i lose responsiveness, i also get on wdm a faster crackle way more often, my a1 is at mme 48k 1024 buffer,wdm i set to 1024 but still as before, what things could i try to make sure i dont get a crack on responsiveness loss or the bad performance in wdm
iurirolho
Re: Voicemeeter potato sound crackling/popping out on responsiveness loss and worse performance on wdm
Postby iurirolho » Sun Sep 15, 2019 10:26 pm
could it be driver related, maybe, what steps could i take to figure out if it is
Postby Vincent Burel » Wed Sep 18, 2019 7:11 am
franckly , everything is possible with Windows... if you cannot get stable audio stream it could mean that you may have to re-install audio drivers...
you can first check that your Voicemeeter and VB-CABLE driver are well installed by checking their name and icon in the Windows / Sound Dialog box as it is explained in this thread:
viewtopic.php?f=7&t=688
Return to “Voicemeeter”
Users browsing this forum: Bing [Bot] and 19 guests
