Voicemeter control via Android App
SSchaffrath
Postby SSchaffrath » Mon Feb 03, 2020 2:47 pm
I would like to ask if it would be possible to control voicemeter via an app like a real world mixer as X32 or the Allen & Heath deskmixers.
Thank you.
Best regards
Sebastian
Re: Voicemeter control via Android App
Postby Vincent Burel » Mon Feb 03, 2020 2:58 pm
possibly if your virtual controller are supporting RTP MIDI.
Voicemeeter could use RTP MIDI as MIDI device to receive message from your mobile device mixer.
(but the best should be to ask to your manufacturer to implement VBAN-MIDI protocol instead... because RTP MIDI is complicated to configure).
SSchaffrath
Postby SSchaffrath » Mon Feb 03, 2020 7:44 pm
First, thx for the fast response.
But i think you didnt understand me right.
My english isnt the best, as you probably already have seen.
My intention to ask was if it could be possible that i can remotely control Voicemeter with a Android App. I dont want to build any app myself, free time to invest in it, is a issue for me.
The reference with the real life Mixer was just to have an Idea how the App could/should look like.
For example: https://play.google.com/store/apps/details?id=com.behringer.android.control.app.xair
Postby Vincent Burel » Mon Feb 03, 2020 7:57 pm
well, RTP MIDI is maybe not available on Android...
so you may try our VBAN-Buttons app: https://play.google.com/store/apps/deta ... banbuttons
but it's only push or 2 positions button.
Return to “Voicemeeter”
Users browsing this forum: No registered users and 13 guests
