Help mapping
Posted: Sun Mar 08, 2020 11:06 am
by adrian142
I am a registered user of Voicemeeter Potato. I find it to be a very powerful audio solution, the one I was looking for.
At the moment I am struggling with all there options, in combination with other audio Hardware/software I am using, which means besides Voicemeeter:
- AmpliTube 4
- Audacity
- Cubase AI 10
- OBS
- BIAS FX 2
- Rocksmith with Rocksmith Cable
- Yousician
- Yamaha AG06 Mixer
When I set VM as default audio driver in Windows and configure all the inputs and outputs, I have a hard time identifying the settings in other programs.
F.e. the view of Voicemeeter in AmpliTube or Cubase can be kind of confusing.
I have a hard time figuring out what the correct settings are to identify my clean guitar signal , my processed guitar signal (coming from AmpliTube/BIAS FX) and maybe separating desktop audio.
When I see the guitar signal in VM on channel #1 it should be easy to track it down in other audio software. But I fail, sad to say. I need help.
This is the setting I want to achieve:
I want to send my guitar signal in the computer (coming from Rocksmith cable or AG06 Input#2).
The signal should be sent to
- Yousician (for keeping track of the notes I've played)
- AmpliTube (or BIAS FX) for sound tweaking
- Cubase (the dry signal and separated the desktop audio (best split into processed guitar sound [AmpliTube/BIAS FX]and backing track [Yousican] or Audacity for recording
Can anyone help?
Best, Adrian
P.S. I will update this question with screenshots and maybe some desktop videos to get it worked out with Your help.
Re: Help mapping
Posted: Sun Mar 08, 2020 12:08 pm
by adrian142
So here is a first video:
https://youtu.be/f76QhTRXERA
Re: Help mapping
Posted: Sun Mar 08, 2020 12:16 pm
by adrian142
And here a screenshots from the various settings dialogs:
https://photos.app.goo.gl/3qmW7LLLYBzKRevJA
Will now add descriptions to screenshots.
Re: Help mapping
Posted: Sun Mar 08, 2020 7:48 pm
by adrian142
Here is a step singled out, where I need help:
Anmerkung 2020-03-08 194621.jpg (213.7 KiB) Viewed 9581 times
I have my mixer setup and a guitar signal (AG06/strip 1).
I selected VM Potato in AmpliTube – but with all the options – I cannot find the signal from my AG06.
What is the missing piece of information?
