ASIO4ALL in certain sitiations needed?
adrian142
Postby adrian142 » Wed Mar 25, 2020 6:36 am
Hi all,
I had problems using Voicemeeter Potato to solve my problem.
The I came across that video that helped me solve it using Voicemeeter and ASIO4ALL:
https://youtu.be/_yEp5mXNv1A?list=WL
My question now is:
Is ASIO4ALl really needed or can I use Voicemeeter Potato with all its options to replicate what is described in the video?
My concern is that ASIO4ALL and Voicemeeter add one unnecessary layer of latency.
Best, Adrian
Re: ASIO4ALL in certain sitiations needed?
Postby Vincent Burel » Wed Mar 25, 2020 9:01 am
In most of use cases: ASIO4ALL is not useful with Voicemeeter.
since Voicemeeter already provides Virtual ASIO driver to connect any DAW directly.
Using ASIO4ALL to connect a DAW in ASIO to Voicemeeter in WDM,
is surely a useless layer (bringing more latency and more audio stability problem).
adrian142
Postby adrian142 » Wed Mar 25, 2020 9:14 am
How do I substitute the routing from within ASIO4ALL with only Voicemeeter Potato:
Anmerkung 2020-03-25 091126.jpg (35.21 KiB) Viewed 689 times
Postby Vincent Burel » Wed Mar 25, 2020 4:16 pm
what application is using ASIO4ALL driver ?
adrian142
Postby adrian142 » Wed Mar 25, 2020 4:20 pm
ASIO drivers are used by: Cubase AI DAW, Yamaha AG06 mixer (with two separate channels (one for guitar, one for voice)).
I am not able to get the right Voicemeeter channels selected.
Here it is step-by-step:
Anmerkung 2020-03-25 153436.jpg (23.28 KiB) Viewed 683 times
Anmerkung 2020-03-25 161113.jpg (88.86 KiB) Viewed 683 times
Anmerkung 2020-03-25 161151.jpg (121.08 KiB) Viewed 683 times
adrian142
Postby adrian142 » Wed Mar 25, 2020 4:21 pm
Anmerkung 2020-03-25 153252.jpg (83.66 KiB) Viewed 683 times
Anmerkung 2020-03-25 153409.jpg (21.08 KiB) Viewed 683 times
adrian142
Postby adrian142 » Thu Mar 26, 2020 10:23 am
Here is a video/screen capture:
https://www.dropbox.com/s/pxrsqzenlxfrd ... s.mkv?dl=0
Why do I hear nothing on VAIO3-VAIO8?
Shouldn't I?
Postby Vincent Burel » Thu Mar 26, 2020 1:24 pm
if you use the virtual insert ASIO driver, you may activate channels one by ones in the system settings dialog box PATCH INSERT
adrian142
Postby adrian142 » Thu Mar 26, 2020 4:27 pm
Thy for the info! Is there anywhere a step-by-step-instruction?
What about the other drivers?
How are they handled?
adrian142
Postby adrian142 » Fri Mar 27, 2020 8:23 pm
Here is a video that shows my problem "live".
I send the desktop audio to all the outgoing channels but inside the daw - nothing!
https://youtu.be/tUtUmd2nb2A
Return to “Voicemeeter”
Users browsing this forum: No registered users and 15 guests
