VB Cable not working
RichardG062
Post by RichardG062 »
I have VB Cable installed on my PC and up to now it has been working well. However I have recently completed a Windows 10 update v1803 and VB Cable is now not working. I have looked at the various sound setting and everything appears to be OK with the status saying this device is working correctly with most recent driver installed. I have tried uninstalling (restarting PC) and then re installing (again restarting PC) but again no sound when |I select VB Cable.
Anyone else have this issue after a Win 10 update? and if so, the solution to fix the problem.
Thank Youi
Richard G
Re: VB Cable not working
you may check all Windows parameters related to the VB-CABLE
- in the Sound Dialog Box / advanced -> Mute / Gain
- in the volume mixer.
- in the privacy settings related to microphone / camera too...
