On Windows 10. After install VB cable,can`t activate Asio Driver
Hello..I have serious problem now,, After install VB cable, sound was not so good with some noise,
so I deinsall VB,, but still my Roland audio inter face kept same problem,so I deinstall Roland driver,
then I install driver again,,but it does not show up...
Windows say` driver is found but problem happened to install,,,,`
I try many way but does not work,,,
So I tried to use another Presonus Interface,,,but same thing happened.
Also MB`s Realtek High Definition Audio driver got same problem.......
What can I do??? Please help me!!
My OS is WIn10 pro 20H2, MB is Gigabyte Technology. (Z68MA-D2H-B3)
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz 3.40 GHz Memory 20GB
GB is NVIDIA GeForce GTX 1650 SUPER ...
Re: On Windows 10. After install VB cable,can`t activate Asio Driver
noise is not expected in VB-CABLE , you may have described your problem before de-installing VB-CABLE.
Now you can check there is no remaining VB-CABLE component in Windows Device Manager.
and follow recommendation to de-install correctly your audiodriver:
if you need more help, you may describe your problem and use case with Screenshot.
Before install VB...there was no problem in my machine,, so maybe there were some bad Compatibility with my set...I guess
So I decided to unintall Vb....but after this ,I can not get back same condition....
So I tried to install VB again.. and uninstall it but still same.....
Now just I want to reintall Roland ASIO driver though ,,,it is impossible.....
my AI is M-16DX,,,quite old machine....so I tried to use Presonus AudioBox i2,
but same,,computer does not find driver again.....
Have you heard a kind of same situation??
Index` Windows Cannot Verify Driver Signature (on signed driver)`
may same situation as me,but they are about Windows7//not Windows 10 /
so.....I am not sure...which one Should I try////if you can teach me I am appreciated....
kenken wrote: ↑Fri Dec 10, 2021 7:20 am Index` Windows Cannot Verify Driver Signature (on signed driver)`
Windows10 20H2 update is problem you said....
I checked it..... there are many 20H2 update ,so Should I uninstall all of them??
we do not get any report on this problem.
And we can say that VB-CABLE can be installed on Windows10 20H2 or 21H1 without any problem.
Maybe You have to re-install it correctly, think to run the setup program in administrator mode.
or update widows again, something i system has been corrupted maybe...
Ok ! I will try it !!
I`ve tried to install VBC ,again ,but this time it said LOADDRV; The path doesnot exist!!
So I could not install VBCable this time /////!! I did with Administrator mode of course!!!..
What can I do now??
What can I do now??
this error happens if you try to install the driver from the ZIP package directly.
You may extract all first and then after run the setup program from the folder containing the extracted files.
Problem has gone at last////!!
After of all I did Windows 10 reinstall with keeping files an Applications....
Now it shows same environment as before problems started..
thank you so much for help..
