VB Setup Issue
cldcp00
VB Setup Issue
Postby cldcp00 » Sun Aug 02, 2020 12:43 am
Hi
I wonder if somebody could explain something with the set up I have with following Voice Meeter VB Cables and a Application called AIMP and Sound Forge.
AIMP is a media player and Sound Forge is Audio Editor. What I am doing is doing playing audio in AIMP and recording it in Sound Forge adding live effects.
Now I have played around but cannot get to work correctly it seems like the recording output and playback is going thought the same Virtual cable causing an echo effect
Regards
Des
TestXpress
Re: VB Setup Issue
Postby TestXpress » Sun Aug 02, 2020 7:36 pm
I don't know the tools, but in general you should configure the output of AIMP to the Cable Input, the Cable Output to Sound Forge input and then finally the output of Sound Forge to your hardware sound device.
You definitely should avoid having loops in your configuration, otherwise you will have echos.
