startup difficulty
jeffjohn1941
startup difficulty
Postby jeffjohn1941 » Fri Jan 25, 2019 12:33 pm
When I wake my Win 10 from sleep. Bluetooth monitor says I am connected to listening device (Roberts Stream), but there's no sound connection. A Win restart does reconnect sound. I did have 'auto-restart' active in menu; is this correct? I inderstand that a startup delay is now incorporated in later versions; would this solve my problem? (currently 2.0.4.4).
Terrific software - I'm thrilled with it - thanks! :D Jeff
jeffjohn1941
Re: startup difficulty
Postby jeffjohn1941 » Fri Jan 25, 2019 12:35 pm
sorry posted on wrong topic area!
Postby Vincent Burel » Fri Jan 25, 2019 1:05 pm
yes, the startup delay (5s per default) is there to allow all other services start... before Voicemeeter attempt to use them.
jeffjohn1941
Postby jeffjohn1941 » Sat Jan 26, 2019 11:36 am
Many thanks for prompt reply. Yes that does seem to be the solution! Regards jeff
