VAIO / VB-CABLE Installation Checking
Postby Vincent Burel » Tue Jan 29, 2019 9:18 am
In some cases, audio driver can be bad installed or partially de-installed and prevent to have an audio system running correctly.
Before re-installing our VB-CABLE or Voicemeeter, it's important to check that the related audio drivers are correctly removed from the system, in the Windows Control Panel / Device Manager:
if you find some part of it in the Device Manager , you may right click on it (to get contextual menu) to de-install it manually, by the windows procedure.
Start by the Sound Controllers (and reboot after)... then check the Audio I/O and possibly remove them by the same way (right click on it and deinstall device).
After a last REBOOT (PC restart) if the Device manager shows nothing else, you can re-install our VB-CABLE or Voicemeeter (and don't forget to REBOOT your computer after).
Are VB-Audio Virtual Devices Well Installed ?
Postby Vincent Burel » Fri Jul 19, 2019 7:46 am
Your VB-CABLE or Voicemeeter VAIO's must appear like on the picture below for Playback and Recording Devices. Otherwise you should re-install them correctly.
Users browsing this forum: No registered users and 37 guests
