After installing an update a long long time ago for windows my soundboard stopped working because VB cable stopped working
How is it not working?
1- I have set VBcable input to listen to my Microphone in the microphone properties in the Sound Control Panel
2- VBcable input detects sound from my microphone
3- VBcable output does not receive the input from the microphone
After testing a bit I have noticed that this only occurs for when listening to my microphone if I set audio to be played through input it will still go to the VBcable output
VBCable Input not going to output when listening to Mic
Re: VBCable Input not going to output when listening to Mic
Hello everyone this is my very first Post after reading most of the instruction on setting up VBcable I have set my cable as explained in the help guide step by step the free version but suddenly a few weeks later no sound through my Free VB-Cable, I decided to do a clean install removing anything that might be in my registry a fresh install but decided to donate and go with VB Cable A /B I try to setup as the free version settings but no sound coming out of either Cables A/B can someone explain to me how to fix this?? could this be a cause from a MS update below are my system specs I have two AV installed I have disable both of them and re-enable them but still no sound coming out from them accept my regular windows driver --->
"Trying to record using AWaveStudio and I get this error message check below also my vb cable are setup accordingly please let me know if its not configured correctly thank you"
Machine Specs:
OS Name Microsoft Windows 10 Enterprise
Version 10.0.18362 Build 18362
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name *******
System Manufacturer Hewlett-Packard
System Model HP Compaq 8200 Elite CMT PC
System Type x64-based PC
System SKU ***********
Processor Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz, 3101 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Hewlett-Packard J01 v02.29, 4/4/2016
SMBIOS Version 2.7
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Hewlett-Packard
BaseBoard Product 1494
BaseBoard Version Not Available
Platform Role Workstation
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.18362.10000"
User Name ***********
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 16.0 GB
Available Physical Memory 6.88 GB
Total Virtual Memory 17.9 GB
Available Virtual Memory 2.99 GB
Page File Space 1.94 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection
Sound Drivers Info--->
Name AMD High Definition Audio Device
Manufacturer Advanced Micro Devices
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1002\5&752B581&1&0001
Driver C:\WINDOWS\SYSTEM32\DRIVERS\ATIHDWT6.SYS (10.0.0.3, 107.52 KB (110,096 bytes), 4/18/2016 11:34 AM)
Name Realtek High Definition Audio
Manufacturer Realtek
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_103C1494&REV_1001\4&377229A9&1&0001
Driver C:\WINDOWS\SYSTEM32\DRIVERS\RTKVHD64.SYS (6.0.1.6730, 3.95 MB (4,145,936 bytes), 8/19/2019 3:24 PM)
Name VB-Audio Cable A
Manufacturer VB-Audio Software
Status OK
PNP Device ID ROOT\MEDIA\0000
Driver C:\WINDOWS\SYSTEM32\DRIVERS\VBAUDIO_CABLEA64_WIN7.SYS (6.1.7600.16385, 40.18 KB (41,144 bytes), 8/21/2019 5:17 PM)
Name VB-Audio Cable B
Status OK
PNP Device ID ROOT\MEDIA\0001
Driver C:\WINDOWS\SYSTEM32\DRIVERS\VBAUDIO_CABLEB64_WIN7.SYS (6.1.7600.16385, 40.18 KB (41,144 bytes), 8/21/2019 5:16 PM)
PS Strange thing when I play one of my Synth Application using ASIO4all sounds come out from the synth to any of the Vbcables something is not configured and I cant figure it out thank you..
Machine Specs:
System Name *******
SMBIOS Version 2.7
BIOS Mode Legacy
Status OK
Status OK
Status OK
Status OK
just want to add that the Listen option is made by Windows and we do not recomment to use it (because can disturb the Voicemeeter workflow for example).
VB-CABLE is basically just a cable to connect 2 applications together (a player to a recorder). If you need more routing / mixing option you may consider using Voicemeeter.
Question will The Voicemeter route it to the speaker to headphones if I connect it to my computer just want to find out if you're saying that using the windows speaker drivers is not recommended please let me know unless I'm not understanding this correctly thank you cheers
i was talking about the LISTEN option provided by Windows.
Voicemeeter can use any device.
