VB-CABLE Information
Posted: Mon Oct 13, 2014 2:19 pm
VB-CABLE is a virtual audio device working as Virtual Audio Cable
As virtual cable, VB-Cable can be used to connect two applications together, typically a player application to a recorder application.
Official Page: http://www.vb-cable.com (download, user manual and video tutorial)
VB-CABLE INSTALLATION PROCESS: STEP BY STEP:
1-Download zip on your local disk (C: system disk).
2-Extract all files in one folder (e.g. temporary folder on C: System Disk "C:\temp")
3-From this local temporary folder: Run Setup program in administrator mode (right click on exe to see the “run as administrator”)
4-Follow instruction : REBOOT after installation
IMPORTANT WARNING: REBOOT AFTER INSTALLATION AND DE-INSTALLATION
(Virtual Audio Device Driver needs this reboot to finalize de-installation or installation)
U P D A T E
UNINSTALL FIRST:
0- Close applications that could the VB-CABLE driver (OBS, Audacity...).
1- Run the Setup program and push the button REMOVE.
2- REBOOT AFTER (IMPORTANT)
Before re-installing you may check
- in Windows Device Manager that VB-CABLE virtual audio drivers is removed (from the game controller section and from the audio I/O section) - if still present you may uninstall them manually from there.
THEN RE-INSTALL:
3- Run the Setup program in administrator mode and push the button INSTALL.
4- REBOOT AFTER (VERY IMPORTANT)
WARNING: the Setup program can be displayed as "not responding" because the installation process can takes several seconds... Just wait until the end of the setup sequence.
Missing 'inf' file... error
Posted: Mon Sep 14, 2020 7:01 am
if you get the following message:
Missing 'inf' file or Driver Package Corrupted
it usually means you are running the SETUP program directly from the ZIP package.
that's why you must EXTRACT all files in a temporary or archive folder first and launch the SETUP program from this regular folder.
