[Feature Request] Macro Button Mouse Key Binds
mix-man
Post by mix-man »
First off, thanks for the awesome software! Now, I am unable to bind any of my mouse buttons to the macros app. Is this possible? I've tried each of the "Mouse L, Mouse R, Mouse M" options and none work with my mouse. More specifically, I would like to bind the MOUSE4 button to a macro.
Re: Macro Button Mouse Key Binds
MAcroButton propose Mouse L,M,R buttons, it should work ... otherwise another process is getting exclusive acces before us?
mix-man
Re: [Feature Request] Macro Button Mouse Key Binds
Post by mix-man »
I'm not real sure. I started using X-Mouse to remap the Mouse 4 button to "SHIFT+F13" .. That works sort of, but is only a bandaid.
