[Feature Request] Load different button map via command
TheTimmaeh
Postby TheTimmaeh » Wed May 23, 2018 2:29 pm
Hey there,
I've been digging into the manual of MacroButtons and I noticed a command called Command.Load, which loads a new config for Voicemeeter Banana.
However there is no command to load new button maps in MacroButtons. Having a load command for MacroButtons would help organize macros as it would be an easy way of creating folders.
I would love to see this in future.
Re: [Feature Request] Load different button map via command
Postby Vincent Burel » Sun May 27, 2018 8:18 am
in the Macro Button System Menu , you have LOAD / SAVE Button map
TheTimmaeh
Postby TheTimmaeh » Thu May 31, 2018 2:37 am
I realize there is an option in the dropdown, but I was specifically looking for a command so I could execute it when pressing a button.
Let's say I have a grid of 8 x 8 (A1 to H8). The first row (A1 - A8) could be folders for different purposes, like button A1 for executing various programs, A2 for window management, A3 for interacting with my Steamlabs OBS setup, etc.
That way I wouldn't have to keep all macros on one button map, but could switch to a different button map (or folder) by simply clicking one button.
Using the option in the dropdown means tabbing out of the game or stop doing whatever I'm doing right now, searching for the right button map, etc.
Postby Vincent Burel » Fri Jun 01, 2018 4:19 pm
ok, i note it, but this version is not really made for that... will see...
peden
Postby peden » Tue Jun 05, 2018 11:09 pm
So you basically want a virtual StreamDeck?
