Load() button map does not expand %% system variables
py2raf
Postby py2raf » Sat Mar 14, 2020 11:14 pm
Hi Vince!
I tried to create a button map Load() using %% environment variable but it didn't work.
Example:
Load("%USERPROFILE%\auto\cq-map.xml");
Will fail. However, if I:
Load("c:\users\rodrigo\auto\cq-map.xml");
Works flawlessly. Just reporting.
As I have posted in other thread, I'm already taking advantage of it!
Documented at https://github.com/rfrht/Voicemeeter-FT ... utton-maps
Thanks for all your hard work and enhancements, Vince!
p.s.: This functionality is missing in Manual - I found in changelog!
Re: Load() button map does not expand %% system variables
Postby Vincent Burel » Tue Mar 17, 2020 10:25 am
yes, right, we forgot this... ok i note it for next update.
Users browsing this forum: No registered users and 6 guests
