Network Mapped Drive not visible in Application
MT32-Sound Pad Lite
in some cases (e.g. if your application is launched in administrator mode),
Network Mapped Drives could not be listed in MT32-Splite Disk Selector.
(this can happen with right access or when UAC Is enabled for example and more again when running 32bits app on 64 bits O/S).
The solution has been given here by answer.microsoft:
Network mapped drives not available on WIndows 10 TP
https://answers.microsoft.com/en-us/ins ... 178?auth=1
This seems to originally comes from technet.microsoft:
Some Programs Cannot Access Network Locations When UAC Is Enabled
https://technet.microsoft.com/en-us/lib ... s.10).aspx
To configure the EnableLinkedConnections registry value
1- Click Start, type regedit in the Start programs and files box, and then press ENTER.
2- Locate and then right-click the registry subkey HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System.
3- Point to New, and then click DWORD Value.
4- Type EnableLinkedConnections, and then press ENTER.
5- Right-click EnableLinkedConnections, and then click Modify.
In the Value data box, type 1, and then click OK.
Exit Registry Editor, and then restart the computer.
