Using headset into PC, and getting&sending audio to 3.5mm connected cell
SyrealTheWolf
Post by SyrealTheWolf »
Good evening,
Maybe an odd setup - maybe not - but I'm at a loss:
Goal:
PC runs a game and has an internet connection. Runs VB Banana. <--- 3.5mm audio cable ---> Cell phone on 4G
Cell phone runs Discord
Ideally:
I want to be able to hear PC sounds via headcheck *check
I want to be able to hear audio from cell on PC headset *check
What I can't figure out is how to get my headset mic audio to go to the cell phone, over Discord (as if it was a 3.5mm headset plugged right into the phone).
I'll post screenshots of my setup tonight when I get home, but thought I'd at least start this to see if it's immediately laughable. Thanks.
LOVE the program.
SyrealTheWolf
Re: Using headset into PC, and getting&sending audio to 3.5mm connected cell
Note - I do notice with this as configured, I'm getting mic sounds in my headset - which I think? makes sense as I'm sending it to the phone, but am perhaps getting it back as well? Unsure.
I'll keep testing.
Screenshot with notes of current setup:
system settings:
Thanks for any advice.
SyrealTheWolf
Just tried this: sending the headset mic to B1, then linking that to the A2 (phone) line.
I don't hear the same sounds as the other way but don't totally understand why.
Will test via Discord.
Gwydion
Post by Gwydion »
Are you still looking for some help or did you figure out the setup?
