WDM Outputs not working
Epic_Boi
Post by Epic_Boi »
If I select the WDM version of my headset or monitor, nothing comes through and in the Voicemmeter Banana System Settings it says that OUT A1 Status is OFF. MME is working. This started after the new windows update but not immediately, only after i restarted my pc the first time after the update.
Re: WDM Outputs not working
you may check samplerate of yuor device, or check that it is not an exclusive mode problem (when using WDM output device, Voicemeeter try to get exclusive access to the device. normally it goes in SHARE mode if not but sometimes it does not work... )
Epic_Boi
Post by Epic_Boi »
those did not help
could you post a screenshot of your voicemeeter system settings dialog box ?
Epic_Boi
Post by Epic_Boi »
One is with wdm and the other is mme: https://imgur.com/a/S7f2GE6
Epic_Boi
Post by Epic_Boi »
So my nvidia gpu driver just crashed and windows fell back to its own display driver, so I reinstalled the latest geforce game ready driver and now WDM is working again, so it must have been a badly installed driver from the windows update.
