Additional Virtual Audio Cables
gdepp
Postby gdepp » Wed Jul 25, 2018 8:37 pm
I was trying to discover if there are any available additional virtual audio cables. I have the main single and A+B. What I am working with I could use a few additional.
Re: Additional Virtual Audio Cables
Postby Vincent Burel » Fri Aug 03, 2018 9:08 am
no , other Virtual Cable are provided with Voicemeeter.
Gwydion
Postby Gwydion » Mon Aug 06, 2018 9:07 pm
Hey, vincent. Can't you grab one more cable by grabbing the hi-fi audio cable? If you don't "activate" the hi-fi aspect, it still functions as an additional cable, right? At least I use it that way! :)
Postby Vincent Burel » Mon Aug 20, 2018 12:14 pm
yes, HIFI Cable can be used like the VB-CABLE , but you just have to check that input and output are in the same samplerate.
llaffer
Postby llaffer » Sun Jan 27, 2019 9:13 pm
Sorry for waking up a zombie post, but I was also looking for a possible 4th virtual cable.
I'm not sure what you are referring to by "HIFI" which can be disabled to work as a 4th cable. Can you elaborate?
Thanks.
Users browsing this forum: Bing [Bot] and 2 guests
