What is the "Pipe size"?
terrybritton
Post by terrybritton »
Vincent,
In the latency manual on page 5, it says, "Note: for VB-CABLE, you can decrease the Internal SR to increase effective pipe size. "
http://vb-audio.pagesperso-orange.fr/Ca ... ttings.pdf
What is the pipe size, and when would I want to change this setting? (For instance, I'm running all my devices at 48000 at the moment...)
Thank you!
Terry
Re: What is the "Pipe size"?
"Pipe size" is an image to represent the internal latency.
