upgrades
jeffjohn1941
upgrades
Post by jeffjohn1941 »
I am somewhat nervous of upgrading Banana from 2.0.4.4 to 2.0.4.7.
Can I simply remove Banana .4 in 'add or remove programmes', reboot and install .7 and reboot?
Or do i have to mess about with Win 10 Pro drivers again?
A step-by-step procedure would be much appreciated! Thanks, Jeff
Re: upgrades
normally yes!
you can de-install Voicemeeter by the "add & remove programme"... then REBOOT...
and after install new version... and reboot.
you may check the audio format of the voicemeeter vaio recording device...
