Voicemeeter - Mic Problems/ Crackling sound / Stutter
Azp3ct-
Post by Azp3ct- »
Hello Dear VB-Audio Friends,
i have a problem with my Setup on Voicemeeter. Everytime when i USE discord, or Shadowplay from Nvidia my Recording Sound of Microphone is Stuttering and Crackling.
I Uninstalled - Installed, checked the Driver-Manager after Uninstall, deleted Drivers if there was any, Rebooted and Installed Fresh, Problem Still persists.
Maybe you guys can Help me Fix This.
My Setup is - Windows 10 64bit on a i9900k / Asus ROG Gaming E Z370 Mainboard. Yamaha MG10XU Audiointerface and Rode Microphone
https://imgur.com/a/ulKtRsx
https://imgur.com/a/THApvHO
Here You can See all Settings i could find to share With you.
I also recordet my self to let you guys Here how it sounds. https://www.youtube.com/watch?v=-V4O3Fu ... e=youtu.be
1. Recording with Shadowplay - Crackling Sound in Voice
2. Recording in Disocrd - Crackling Sound in Voice
3. Recording in Audacity - NO Crackling Sound in Voice
If any aditional Informations are needed, let me know iam more then Happy to Provide anything which can help us find a solution.
Kind regards, Azp3ct-
Azp3ct-
Re: Voicemeeter - Mic Problems/ Crackling sound / Stutter
Post by Azp3ct- »
Has no one a Solution ?
Azp3ct-
Post by Azp3ct- »
I would also Tip someone who could help me fix this Problem, iam a Professional Pubg Player and right now i can not stream, or Record With Voicemeeter. I really need help :(
if well installed, all is a question of configuration, please follow recomendation on this topic:
viewtopic.php?f=6&t=451
Azp3ct-
Post by Azp3ct- »
Vincent Burel wrote:if well installed, all is a question of configuration, please follow recomendation on this topic:
I did follow those Instructions, i re-installed / rebootet / installed / rebootet
i checkd all drivers, i let everythion on Normal without changing anything, the Problem Persists, as u can see my screenshots of my Settings, i cant figure out the Problem, i also Provided a video where you can hear how its cutting of every second....
i just dont know what to do anymore..
ok, change the device selected as output A1
if it does not work with ASIO , try WDM, or MME
otherwise select another device (your onboard audio board as output A1).
if you cannot find a solution like this... ask to shadowplay what's happening...
Azp3ct-
Post by Azp3ct- »
Vincent Burel wrote:ok, change the device selected as output A1
its not Only in Shadowplay, its Also in Discord -Teamspeak, everywhere where my Mic is Recordet. My Normal sound from Desktop is Fine, my Microphone been recordet sounds bad
Azp3ct-
Post by Azp3ct- »
i changed the Output device still my Microphone recording sounds the same crackeling and stutterd
you may identify if the problem is coming from the input only, the output only, or the link to shadowplay only.
Discord is not connected to your MIC , but to Voicemeeter output ? Right ?
you have set this recording device as default communication / recording device ?
Azp3ct-
Post by Azp3ct- »
Vincent Burel wrote:you may identify if the problem is coming from the input only, the output only, or the link to shadowplay only.
you can see my settings HERE
Input Is Voicemeeter Aux Output - Output is Voicemeeter Input
it does not matter where i use my Microphone everywhere it sounds Bad in every voice or recording software with Cracks and Stutters check the Youtube link too so you can here i dont know what to do anymore....
